Buna Am de facut pentru un laborator un microcontroller pentru o tastatura ps2 in cod VHDL care sa afiseze literele pe afisajul cu 7 segmente a placii Nexys2 si am o problema .Am facut un cod,dar cand il simulez nu se modifica nimic la registrele care trebuie sa imi shift-eze codul si sa il memoreze si nu stiu de ce.Ma poate ajuta cineva? Am scris mai jos codul la care am lucrat. Nu am verificat pe placuta,dar banuiesc ca nu ar merge din moment ce in simulator nu este nimic pe iesire.
-------------------------------------------DEBOUNCING----------------------------------------
LIBRARY ieee;
USE ieee.std_logic_1164.all;
USE ieee.std_logic_unsigned.all;
ENTITY debounce IS
GENERIC(
counter_size : INTEGER := 19); --counter size (19 bits gives 10.5ms with 50MHz clock)
PORT(
clk : IN STD_LOGIC; --input clock
button : IN STD_LOGIC; --input signal to be debounced
result : OUT STD_LOGIC); --debounced signal
END debounce;
ARCHITECTURE logic OF debounce IS
SIGNAL flipflops : STD_LOGIC_VECTOR(1 DOWNTO 0); --input flip flops
SIGNAL counter_set : STD_LOGIC; --sync reset to zero
SIGNAL counter_out : STD_LOGIC_VECTOR(counter_size DOWNTO 0) := (OTHERS => '0'); --counter output
BEGIN
counter_set <= flipflops(0) xor flipflops(1); --determine when to start/reset counter
PROCESS(clk)
BEGIN
IF(clk'EVENT and clk = '1') THEN
flipflops(0) <= button;
flipflops(1) <= flipflops(0);
If(counter_set = '1') THEN --reset counter because input is changing
counter_out <= (OTHERS => '0');
ELSIF(counter_out(counter_size) = '0') THEN --stable input time is not yet met
counter_out <= counter_out + 1;
ELSE --stable input time is met
result <= flipflops(1);
END IF;
END IF;
END PROCESS;
END logic;
--------------------------------------------REGISTRU-----------------------------------------
-- FileName: ps2_keyboard.vhd
LIBRARY ieee;
ENTITY ps2_keyboard IS
GENERIC(
clk_freq : INTEGER := 50_000_000; --system clock frequency in Hz
debounce_counter_size : INTEGER := 8); --set such that (2^size)/clk_freq = 5us (size = 8 for 50MHz)
PORT(
clk : IN STD_LOGIC; --system clock
ps2_clk : IN STD_LOGIC; --clock signal from PS/2 keyboard
ps2_data : IN STD_LOGIC; --data signal from PS/2 keyboard
ps2_code_new : OUT STD_LOGIC; --flag that new PS/2 code is available on ps2_code bus
ps2_code : OUT STD_LOGIC_VECTOR(7 DOWNTO 0) --code received from PS/2
END ps2_keyboard;
ARCHITECTURE logic OF ps2_keyboard IS
SIGNAL sync_ffs : STD_LOGIC_VECTOR(1 DOWNTO 0); --synchronizer flip-flops for PS/2 signals
SIGNAL ps2_clk_int : STD_LOGIC; --debounced clock signal from PS/2 keyboard
SIGNAL ps2_data_int : STD_LOGIC; --debounced data signal from PS/2 keyboard
SIGNAL ps2_word : STD_LOGIC_VECTOR(10 DOWNTO 0); --stores the ps2 data word
SIGNAL error : STD_LOGIC; --validate parity, start, and stop bits
SIGNAL count_idle : INTEGER RANGE 0 TO clk_freq/18_000; --counter to determine PS/2 is idle
--declare debounce component for debouncing PS2 input signals
COMPONENT debounce IS
GENERIC(
counter_size : INTEGER); --debounce period (in seconds) = 2^counter_size/(clk freq in Hz)
PORT(
END COMPONENT;
BEGIN
PROCESS(clk)
BEGIN
IF(clk'EVENT AND clk = '1') THEN --rising edge of system clock
sync_ffs(0) <= ps2_clk; --synchronize PS/2 clock signal
sync_ffs(1) <= ps2_data; --synchronize PS/2 data signal
END IF;
END PROCESS;
--debounce PS2 input signals
debounce_ps2_clk: debounce
GENERIC MAP(counter_size => debounce_counter_size)
PORT MAP(clk => clk, button => sync_ffs(0), result => ps2_clk_int);
debounce_ps2_data: debounce
PORT MAP(clk => clk, button => sync_ffs(1), result => ps2_data_int);
--input PS2 data
PROCESS(ps2_clk_int)
BEGIN
IF(ps2_clk_int'EVENT AND ps2_clk_int = '0') THEN --falling edge of PS2 clock
ps2_word <= ps2_data_int & ps2_word(10 DOWNTO 1); --shift in PS2 data bit
END IF;
END PROCESS;
--verify that parity, start, and stop bits are all correct
error <= NOT (NOT ps2_word(0) AND ps2_word(10) AND (ps2_word(9) XOR ps2_word (8) XOR
ps2_word(7) XOR ps2_word(6) XOR ps2_word(5) XOR ps2_word(4) XOR ps2_word(3) XOR
ps2_word(2) XOR ps2_word(1)));
--determine if PS2 port is idle (i.e. last transaction is finished) and output result
PROCESS(clk)
BEGIN
IF(ps2_clk_int = '0') THEN --low PS2 clock, PS/2 is active
count_idle <= 0; --reset idle counter
ELSIF(count_idle /= clk_freq/ 18_000) THEN --PS2 clock has been high less than a half clock period (<55us)
count_idle <= count_idle + 1; --continue counting
END IF;
IF(count_idle = clk_freq/ 18_000 AND error = '0') THEN --idle threshold reached and no errors detected
ps2_code_new <= '1'; --set flag that new PS/2 code is available
ps2_code <= ps2_word(8 DOWNTO 1); --output new PS/2 code
ELSE --PS/2 port active or error detected
ps2_code_new <= '0'; --set flag that PS/2 transaction is in progress
END IF;
END IF;
END PROCESS;
END logic
LIBRARY ieee;
ENTITY debounce IS
GENERIC(
PORT(
END debounce;
BEGIN
PROCESS(clk)
BEGIN
END IF;
END IF;
END PROCESS;
END logic;
LIBRARY ieee;
GENERIC(
PORT(
END ps2_keyboard;
GENERIC(
PORT(
END COMPONENT;
BEGIN
PROCESS(clk)
BEGIN
END IF;
END PROCESS;
--input PS2 data
BEGIN
END IF;
END PROCESS;
PROCESS(clk)
BEGIN
END IF;
END IF;
END IF;
END PROCESS;
END logic
